Tools for MEP Design
jtm2020hyo
Message 1 of 8
jtm2020hyo
Recently I found an add-on called USE-all.com very useful for the Electric plan design, this tool basically do a lot of things automatically, so now I want find more tools for Mechanical Electric Plumb design. I request for suggestions. PD: I call design to everything before BIM for example: in Architecture you do a "design" in Formit before use Revit for mep, actually I want use AutoCAD MEP for BIM but I need a tool for the "design" before BIM.
Replies (7)
Message 2 of 8
AhmedA.Rahman
please check the following link, i think will help you
http://www.wikimep.com/2018/02/all-mep-soft.html?fbclid=IwAR2OVUyKnHmwAwGaQqdMpHPH_pw5cOE5tfICo3uUUc...
Ahmed Abdel Rahman
CADD Manager
Autodesk Ambassador GOLD
Autodesk Certified Professional
Message 3 of 8
jtm2020hyo
wow, thanks for the link sir. awesome tools inside the link.
Did you create those tools?
Is your name sound familiar, Are you a blogger or YouTuber?
Message 4 of 8
jtm2020hyo
Do you know any tool or any way to create a Single Line Diagram importing a CSV or Xls excel  file?
Message 5 of 8
AhmedA.Rahman
No, but i will search for you and you can try this tool from Schneider Electric
How to create single line diagram with Net Genie in Ecodial Plugin for AutoCAD
Ahmed Abdel Rahman
CADD Manager
Message 6 of 8
jtm2020hyo
this what exactly I need, create Single Line Diagrams importing Excel file.
in the addon EcoDial, this function is called Load List fed-from Excel spreadsheet, but is already not available on their website and Autodesk store. the new app, Ecostruxure, replaced EcoDial, but already not have this import function.
Message 7 of 8
jtm2020hyo
Can you share the last version of EcoDial plugin, please?
Message 8 of 8
AhmedA.Rahman
i searching for you, but it's not available now.
you can check the following links i think it will help you
Electrical design tools
https://electrical-engineering-portal.com/download-center/electrical-software
Electrical tools (MS Excel Spreadsheets)
https://electrical-engineering-portal.com/download-center/electrical-ms-excel-spreadsheets
Ahmed Abdel Rahman
CADD Manager
