Different thickness of the same polyline in different drawings
Hello everyone,
I was looking for the answer to this question on this forum on the Internet, but could not find it, therefore, let's go:
I downloaded the drawing on the Siemens website for insertion into my project.
DXF drawing (link - https://www.automation.siemens.com/bilddb/interfaces/InterfaceImageDB.asmx/GetImageVariant?objectkey...)
Further, I saved this drawing in the DWG format and started working with it, however, I noticed strangeness about the line weight.
I set all the parameters to display the line weight in the drawing.
Made so that all lines of the downloaded drawing were on the same layer - "0"
Set the weight and color of the line on the one layer
In the layer set the default line weight
But what I see is the picture below.
The line is all the same thick - that is, 0.2 mm thick
If I set the line weight to 0.0 mm - then it becomes thin, as if I turned off the display of line weights - it sounds very strange, but it is.
What I did was copy all the lines to another drawing of the DWG format - all the lines began to be displayed correctly.
If I copy back (to the drawing in which there are problems with the display), then all the lines become the thickness of which they were, that is, 0.2 mm ...
What could it be?
Maybe there are some hidden settings for DXF drawing ???
Tell me please
AutoCAD 2020 version
