We have resently introduced a set of tool palettes aross the company and one of the user how had been using them and found that the suddenly dont work when thei click on a block nothing happend s nothing get inserted into the drawing when they clock on a polyline that works fine but the blocks jusyt do nothing
any ideas?
Have the dwg file that contain the blocks moved since the palette was created?
If the block host drawing file is moved or deleted, there will be an error message on the command line after trying to insert the block from the palette. Press the F2 key to see the command line history and you should see something similar to:-
Source drawing "D:\Path\Blocklib.dwg" for block "Block Name" not found.
This will help track down the missing block drawing file
Are you still having a problem with this one user not being able to insert the blocks from the tool palette? If so, are you getting any type of error message and if you are, can you get a screen capture of the error?
I'm having a similar issue. Most of the blocks work fine, but a few I have recently updated or added are not working. It allows me to add the block to the palette, but when I click on it , nothing. On the tool palette the image preview shows a white box and I get the error:
Block definition "xxx" is not found in the source drawing "x/x.dwg"
I have purged and audited the block itself and the source drawing and reinserted the block. This is all on a network drive.
Thanks for any suggestions
-RAD
Is the block source drawing file referenced in the Palette tool by just the filename or does it include the full path?
If it's only the filename without the path, AutoCAD will look through your Support Files Search Path (Options, Files tab) to find the file. Is it possible that you have another file by that same name in a location that would be found sooner in a Support Files path search?
If this is the case, I would recommend editing your Palette tools so they include the full path.
"X/X.dwg" ???
Please post the real DWG Path, Filename and Blockname.
Or test yourself with Path, filename, Blockname without special characters.
Sebastian
