AutoCAD Forum
to lock or not
2 REPLIES 2
CliffTurnerFuse
368 Views, 2 Replies
to lock or not
I must have pushed some button unknown to me.
I want to lock a viewport.
I usually make view/lock/on then select.
Now it says the viewport I chose is "1 was not in the working set"
I went to HELP and was directed to Tools/Xref and Block In place Editing/Add to Working Set"
I am then told "Command not allowed, you must be it same space as the reference"
What ????
I done this in AutoCAD for decades.
What's a Working Set ?
What did I do to mess it all up ?
Help !
Read Ya Later -cliff
2 REPLIES 2
pendean
in reply to: CliffTurnerFuse
Are you in BEDIT command, aka block editor? That's normally when that error shows up.
Close and reopen AutoCAD and try it again?
Delete the layout, create a new one, and start over yet? Watch your viewport layer.
Thanks for quick reply.
Solved it quickly
Thanks -Cliff
Forma Design Contest
