Title Block not scaling appropriately in Paper Space
Hi All,
So normally for assignments we submit a title block in Model Space and scale to match drawings and the submit howeve for this exercise the title block must be in paper space since we're learning about 3D layouts and drawing and isometric and then using the base command.
However when inserting my title block and scaling it to the paperspace it is either too wide or too long that even the scale/reference commands can't seem to fix. I've attached a screenshot.
How can I fix this problem?
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
By default a titleblock is not scaled, only the border could be used as scaleable block (also not very common as the markers for folding are not really useful when scaled from A4 to A0 or so).
The most common is to have either a border block for each papersize or to use dynamic block to get that working.
Upload a drawing so we can see how your block was created (unscaled size), how your paperspace and how your pagesetup are defined.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
imadHabash
Hi and Welcome to AutoDesk Forum,
I think that you have to check the scale factor (see attached) when inserting title block.
Imad Habash
Pointdump
Jorge,
You might need to Scale >> Explode >> Stretch to get the Titleblock to fit:
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
CADmonkey_UK_Building_Services
Dave,
Sorry but how can someone of your obvious experience tell someone else to explode a block so readily like that? That's terrible advice. Explode is an awful tool in the wrong hands.
The OP should EDIT the block, unless you want to explain how his attributes all turned into scrap.
If the block is good in Mspace, then it will be good in Pspace with the right scale. The scale of the block in Pspace is ideally 1:1 ie X-1, Y=1, Z=1.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
Pointdump
CM,
"Sorry but how can someone of your obvious experience tell someone else to explode a block so readily like that? That's terrible advice. Explode is an awful tool in the wrong hands."
1. My example had no attributes.
2. Without attributes, exploding is the fastest way to size the TB.
3. Scaling alone doesn't work; it constrains to original proportions.
4. Until the Title Block is in the Layout, how would you know what to edit?
5. If you use Burst, you might miss out on a learning moment.
If we're talking about best workflow, then @Alfred.NESWADBA says it all:
"The most common is to have either a border block for each papersize or to use dynamic block to get that working."
Dave
Dave Stoll
Las Vegas, Nevada
