AutoCAD Forum
The untouchable PLine
14 REPLIES 14
Message 1 of 15
475 Views, 14 Replies
Hello All,
I have made a pline through some schedules to remind myself to make some changes. Today when I opened the drawings to delete them as I made the changes, I can't select any of them. They don't print on paper but they are still visable. I've purged, audited, flattened (even though it's all 2D) and purged but nothing has happened.
Any suggestions on how to be able to select it again?
Thanks.
Hello All,
Thanks.
14 REPLIES 14
Message 2 of 15
DID YOU TRY TURNING IT OFF AND ON AGAIN?
Message 3 of 15
Yes I did, no luck.
Yes I did, no luck.
Message 4 of 15
ukdxb012
ukdxb012
Is the object on a locked layer?
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Duncan Brannan
Twitter | LinkedIn
Message 5 of 15
in reply to: ukdxb012
It doesn't give me the option to select it. Not on a locked layer or defpoints.
Message 6 of 15
ukdxb012
ukdxb012
Make a backup of the file. Then in the copy try this...
1. select "CTRL"+"A" to select all.
2. delete all of the entities
3. very important step, select "OOPS", do not leave this step out.
Can you select other items in the DWG and make multiple selections?
Have you considered selecting all objects and pasting in new DWG?
Duncan Brannan
Twitter | LinkedIn
Duncan Brannan
Twitter | LinkedIn
Message 7 of 15
nestly2
nestly2
Perhaps the PLine was accidentally drawn in the other space?  ie if you're currently in Modelspace, switch to Paperspace and try selecting it... or vice-versa.
Message 8 of 15
braudpat
braudpat
Hello
Is it possible to get a copy of your DWG ?
If YES, please explain where is the "famous" Pline !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Hello
Patrice BRAUD
Message 9 of 15
imadHabash
imadHabash
check layers ( 0 & Defpoints ) freezing these two layers or turning them off will cause such a problem
Imad Habash
Imad Habash
Message 10 of 15
Kent1Cooper
in reply to: imadHabash
Kent1Cooper
That was the first thing that came to my mind, but that can't be the issue, because they already said it's not on the Defpoints Layer.  Things on that Layer will be visible but not selectable or snap-to-able if Layer 0 is off or frozen, but it doesn't go both ways -- things on Layer 0 [or any other] are not so affected if the Defpoints Layer is off or frozen.
Kent Cooper, AIA
Kent Cooper, AIA
Message 11 of 15
pendean
in reply to: Kent1Cooper
pendean
Community Legend
Community Legend
We need that magic DWG file with the undeletable pline for us to all to explore.
Message 12 of 15
in reply to: pendean
Sorry no can do with access to the DWG.
The pline is on layer 0. and it is turned on and unlocked.
There seems to be no solution to this so I will just work with it there.
Message 13 of 15
pendean
pendean
Community Legend
Community Legend
See the two solutions (in the same reply) here for a similar issue, but with text http://forums.augi.com/showthread.php?47793-Text-mysteriously-on-Layer-0-can-t-select-to-delete
Message 14 of 15
braudpat
braudpat
Hello
If your DWG is "secret" !
Why you can't do a WBLOCK of ONLY the magic Pline, check that the new DWG has ALWAYS the problem !
and share this New DWG with us ?
With very high level programming (especially in ARX) and the Reactors, everything is possible !
Patrice BRAUD
Hello
Patrice BRAUD
Message 15 of 15
braudpat
braudpat
Hello
An other question : are you running ACAD MAP 201X or ACAD CIVIL 201X ?
Patrice BRAUD
Hello
Patrice BRAUD
AutoCAD Inside the Factory
