The right way to rotate viewport in paper space
Message 1 of 10
Should I rotate the viewport using the rotate function? I am not sure the degree I want to rotate. Just eyeball it?
Replies (9)
Message 2 of 10
I only want to rotate the drawing inside the viewport rather than rotating the viewport. I want to keep the same location and shape of the VP. How to do that?
Message 3 of 10
cadffm
Message 4 of 10
MMcCall402
My preference is the ALIGNSPACE from the Express Tools.  It works much like the Align command for objects.  I use it to set the viewport rotation, then I set the scale, pan around to fine tune the location, then lock the viewport.  After that I set the UCS to view so any mtext or multileader I make thru the viewport pickup the alignment of the viewport as a rotation of 0.   Nothing in model space is affected by this.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 5 of 10
john.vellek
Hi @Anonymous,
If you want to rotate the model inside your viewport, you might consider DVIEW>Twist.
I made a quick video for you that shows me doing this twice in a viewport. (just so you don't miss the simplicity of using the feature)
John Vellek
Message 6 of 10
paullimapa
The replies by others contain steps that will work.
But you'll have to Zoom to the location & set the Vport's scale factor to match with the original.
The advantages of rotating the Pspace Vport is that you don't have to do any of the above steps.
Is there a reason why you don't want to just Rotate the Vport?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 7 of 10
john.vellek
Hi @Anonymous,
There are some good suggestions here in this thread as well as your other one. Please reward those contributions with kudos if they helped and please also mark a post or posts as solutions if they resolved your question.
John Vellek
Message 8 of 10
tboehler
"Is there a reason why you don't want to just Rotate the Vport?"
This is a good reason.
Message 9 of 10
john.vellek
Hi @tboehler,
You can do it this way and then XCLIP to  have it fit within your page. Just another option for you to try.
John Vellek
Message 10 of 10
tboehler
Correct.
