Hi All,
I am struggling to get my title block to display correctly in PDFs plotted from AutoCAD LT.
In the layout the text in the block (the text is all placed as attributes of the block) looks like this:
Layout View
....whereas the PDF displays like this, with the text running out of the fields in the block:
PDF View
Is anyone able to set me on the right path with this? I imagine it's a simple fix but I am a novice and this is perplexing me.
Thanks and cheers,
Mike
Solved by pendean. Go to Solution.
Hi Dean,
Thanks for your reply.
I think I was using the standard AutoCAD 'DWG to PDF.pc3' to create the PDF. I looked through the custom settings and under PDF Options>Font Handling it was set to 'Capture fonts used in the drawing'. The font is Cantarell, which I added to the library of fonts which may be part of the problem. I have just changed the setting over to 'Covert all text to geometry' and this has resulted in the saved PDF being true to the layout view. File size has also reduced dramatically, which is a bonus.
I'm not sure if this is the perfect solution but it is perfect for my basic needs - as long as the PDF displays correctly I am happy.
Thank you very much for your suggestions and for pointing me in the right direction - there's no way I would have found that on my own. I have just made the switch from Draftsight and am loving the help and resources available for AutoCAD. Thanks again!
All the best,
Mike
