AutoCAD Forum
Text Height under the Dimension Style Manger
4 REPLIES 4
octavio2
323 Views, 4 Replies
AutoCAD 2023:
Text Height entry under the Text tab of the Dimension Style Manager dialog is locked and cannot be changed.
How to unlock it?
4 REPLIES 4
cadffm
in reply to: octavio2
you locked the height in the used STYLE
set to varrie (height 0) and test it again
Sebastian
octavio2
in reply to: cadffm
Not sure where I do change it to "0".  Where I find if it is locked? Please advise.
(The number is grayed like it cannot be changed, it then means that it is locked, but where I do unlock it?  Please advise.)
ВeekeeCZ
Change it, close and reopen DIMSTYLE dialog.
cadffm
>>"you locked the height in the used STYLE"
Style is a command to bring up text STYLE dialog.
See BeekeeCZs post, the screenshots showing the fast way to open STYLE dialog from dimstyle dialog
Thx @ВeekeeCZ
Sebastian
AutoCAD Inside the Factory
