- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Firstly, I'm not certain that this is a AutoCAD problem or an operating system issue, but I figured this would be my first and best option for a solution.
I'm using AutoCAD 2016.
In Paper space I cannot edit Text in either plain text or in a table, I can click on the Text but the dialogue box does not pop up to enable editing, If I'm trying to fill text into a table I can click on the cell and the cell highlights to modify the cell but once again I cannot get the dialogue box to appear.
I always use one layer per component. I'm used to being able to change the layer a component is on by using the Drop down layer control. If I try this now, all that happens is that I change the current layer. I can still change the layer a component is on by using the Properties Control but this is slow to use.
The above started to occur yesterday, mid way through the working day. It was fine in the morning but became problematic as the day wore on.
Any assistance would be greatly appreciated.
