Text changes size when pasted into a block
I am trying to copy text into a block, but when I paste it into the block it comes out much smaller. Any ideas?
The text is purposely on paperspace in case you guys were wondering. Thanks!
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I am not sure what your process is here. Can you attach a file with your block and some sample text so i can give you some suggestions?
John Vellek
Hey John,
Thank you for the quick response!
I'll attach my drawing.
john.vellek
Hi @Anonymous,
I copied the text from the top into a lower spot in your Mtext. It retained its original size of 1/32"
Since it is already part of the same Mtext is there a reson not to just eliminate the blank space between bodies of text?
John Vellek
Hi John,
Thank you for all your help. It was actually a drawing units issue. I needed to make my precision higher. When I did that, I noticed that some of my text were different sizes Smiley Sad
I just had to make everything the same size. Easy fix!
