clipping geolocation map
Is there a way to trim out part of a map referenced in using geolocation and leave the surround map there? I'd like to be able to draft in the actual location without the map in the background, but still have the surrounding map as a reference.
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I don't think you can do that but if you place another viewport or wipeout over it that might work. Can you attach your file and I will give it a try?
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
