Table sum roundup
Table sum roundup
gandi.nbgd
Message 1 of 15
Table sum roundup
gandi.nbgd
I need some help with rounding sum numbers in autocad table. Tried some things like round() and trunc(), but it doesn't work, or I'm doing something wrong.
All this areas are linked to hatch in model, and their field looks like this: (with conversion factor of 0.0001 (cm2-m2))
All I need is simple thing at first, sum at the end to use this two decimal numbers when doing the math, and not the whole 164.366344 for example. So end result needs to be 2420.61 instead of 2420.59.
Thanks in advance!
Replies (14)
Message 2 of 15
Patchy
It works that way same as excel.
Message 3 of 15
JTBWorld
Try something like this:
round(a1*100)/100 +round(a2*100)/100 +round(a3*100)/100
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 4 of 15
gandi.nbgd
No luck, same wrong number
Message 5 of 15
JTBWorld
Can you upload a sample DWG?
Jimmy Bergmark
Message 6 of 15
gandi.nbgd
Here is one example of this problem
Message 7 of 15
cadffm
Autocad fields alway calculate with the real values, not with your display values
Sebastian
Message 8 of 15
JTBWorld
You need to use this:
=round(b1*0.01)/0.01 +round(b2*0.01)/0.01 +round(b3*0.01)/0.01+round(b4*0.01)/0.01
Jimmy Bergmark
Message 9 of 15
gandi.nbgd
Worked, thank you very much !
Message 10 of 15
st19675
Hello to everyone,
Thank god finally found the solution to a similar problem I have.
Hope someone can solve my problem:
I have a table with Object Area Fields inside. Also I have a column sum. I would like to roundup numbers like: 82.09 to 82.10, 1.66 to 1.70, 83.03 to 83.00....
Hope someone can help me.
Thanks a lot in advance 🙂
Message 11 of 15
JTBWorld
Round 83.03 to 83.00 or 84.00?
Jimmy Bergmark
Message 12 of 15
st19675
Thank you for your fast answer Jimmy,
I need to round up  from 0.05 up or round down from 0.04 down, as for example: 73.91 to 73.90, 75.56 to 75.60, 5.25 to 5.30, etc
Thanks a LOT 🙂
Message 13 of 15
JTBWorld
That would be like this: round(A1*10)/10
Jimmy Bergmark
Message 14 of 15
st19675
Finally it worked like this:
ROUND(A1/0.05)*0.05
Thank you very much!
Message 15 of 15
wquevedoPBBV4
Thank you so much.
