Periodically the gray grid (defpoints) for tables in my files will become offset from where they should be. Meaning the cell contents will be in the correct place but the grid lines will be in an entirely different place in the drawing.
Sometimes if you double click in a cell; the grid will correct its placement.
Sometimes you can copy the table to the clipboard, delete the bad table and a new good table will paste correctly.
The problem really throws you off when you zoom extents and it zooms way out to the grid lines.
Has anyone else seen this problem?
Is there a solution?
John
Hi @Anonymous,
Does this still happen if you toggle Hardware Acceleration in GRAPHICSCONFIG?
Can you attach a sample file for me to investigate?
I have changed graphicsconfig and test.
I will not know right away because it does not happen all the time.
-John
