Table Cell Border Double Line
Message 1 of 13
Good morning all,
Today, I am trying to determine why, whenever I try to change a cell border in an AutoCAD 2015/16/17 table to a double line, it will display in the preview window, but does not become active in the actual table.  I have a tablestyle created called Standard, with a lineweight of ByLayer.  The layer lineweight is default.  It does not matter what cell, or cells, in the table are selected, the results are the same.  This is true for all four borders of the cell, none will be double lined.  The cells are not locked.
Suggestions are most welcome - many thanks in advance!
Replies (12)
Message 2 of 13
imadHabash
I think that you have to check and select the spacing and border type as shown in the image :
Imad Habash
Message 3 of 13
Thank you for your suggestion.  I had located and utilized these steps previously without achieving the desired results, and thus, the reason for my post.  Here are some screen captures of the current settings.  I believe there is something that is overriding them, as they will not stay set.  For example, I will change the lineweight from 'ByBlock' to 'ByLayer', save and close the dialog box.  However, when I view the table, the settings have not changed. This is the same behavior for the double line setting.  Note in the screen captures below that I have tried to modify the individual cell as well, not just in the tablestyle.  If I could determine what is causing the changes to be rejected that might solve the issue.
Message 4 of 13
pendean
Community Legend
Community Legend
Show us your actual DWG file with the table please.
Message 5 of 13
Hello Dean,
Thank you for your assistance.  I am not certain how this will help solve the riddle, but here is a pic of the DWG file.  Did you want the actual file itself?  If so, I can share that.
Message 6 of 13
john.vellek
Hi @Anonymous,
Yes, if you could attach the actual file or another with the same issue, I would be happy to take a look at the problem for you.
John Vellek
Message 7 of 13
doni49
My guess is that your table's cell/row is not set to Title (but that's what you're editing in the screenshots you've shown us).
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 8 of 13
Thank you for your assistance Don.  I have attached a screen capture of my cell properties.  I don't think that is the issue?  Something seems to be keeping me from changing the settings to a persistent state.  I change them in the dialog box, but then they revert back once I close the box.  I have to believe therein lies the rub.
Message 9 of 13
Hello John,
Thank you for your offer to help me.  This link should give you access to the file:  Project 11-5 R2.  If there is more I can provide please let me, whether details, or other.
Message 10 of 13
doni49
That sounds like your table is linked to an Excel sheet and it's taking its formatting from the Excel Sheet.
Don Ireland
Message 11 of 13
john.vellek
Hi @Anonymous,
I opened your table style, selected Double Line (for the Title area) and set the spacing to 1".
Looks like it is working fine now.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 12 of 13
doni49
Great catch John!
The row height is 2'10 1/4" while the gap between the two lines is only 3/64" so given that ratio, the double line would not be visible.  It goes to show that sometimes it's the simplest things.
Don Ireland
Message 13 of 13
pendean
Community Legend
Community Legend
No, sorry, I meant for you to actually post the DWG file itself for us to look at on our own.
