SWEEP Command issue.
philip.barcy
philip.barcy
Command:
SWEEP
Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid
Select objects to sweep or [MOde]: 1 found
Select sweep path or [Alignment/Base point/Scale/Twist]:
Modeling Operation Error:
Error Code Number is 115063
Unable to sweep 1 selected objects.
I never had this problem. I am unable to resolve this issue as I have saved the drawing and close the AutoCAD 2022. Open it again and hope it works but it didn't! So I exploded the ring into 2 circles. I clicked both circles into Region and Subject both circles to become the thickness of circle so I can create the ring into the pipeline in radius by using Sweep command. But the error appeared as above (highlighted red). Please advise! Thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
868 Vistas
2 Respuestas
Respuestas (2)
Valentin-WSP
@philip.barcy ,
Try to SWEEP from the other end of line.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
philip.barcy
Solución aceptada
Found the cause of the problem is that the straight line is opposite of the radius line see the pic!
0 Me gusta
