philip.barcy
866 Vistas, 2 Respuestas
SWEEP Command issue.
Command:
SWEEP
Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid
Select objects to sweep or [MOde]: 1 found
Select sweep path or [Alignment/Base point/Scale/Twist]:
Modeling Operation Error:
Error Code Number is 115063
Unable to sweep 1 selected objects.
I never had this problem. I am unable to resolve this issue as I have saved the drawing and close the AutoCAD 2022. Open it again and hope it works but it didn't! So I exploded the ring into 2 circles. I clicked both circles into Region and Subject both circles to become the thickness of circle so I can create the ring into the pipeline in radius by using Sweep command. But the error appeared as above (highlighted red). Please advise! Thanks!
