Surface Area of 3d face
Message 1 of 12
I have a dished end and i wish to find what the inner surface area is. I have created a model of the end, whats the best way to find the surface area.
I have been told to explode the model and pick on the suface but this does not seem to work.
Autodesk inventor seems to have the same problem.
Its a fundamental requirement when one wants to apply pressure or even to find the surface area when painting etc. See attachment
Any suggestions please.
Replies (11)
Message 2 of 12
imadHabash
you can do it by SOLIDEDIT  copy faces command ( see attached ) then by Properties dialog.
Good Luck..
Imad Habash
Message 3 of 12
Thanks for the reply, I have tried your method ,copied the face but when I go to properties it won't give me the area, I think your method works
on a flat surface but not on a curved surface.
Regards
Message 4 of 12
imadHabash
would you post the 3D shape here as CAD file?
Waiting..
Imad Habash
Message 5 of 12
Please see attached fil as requested
Regards
Message 6 of 12
imadHabash
HI,
after copy face use MEASUREGEOM command to get area.is it ok!!
Command: MEASUREGEOM
Enter an option [Distance/Radius/Angle/ARea/Volume] <Distance>:
Imad Habash
Message 7 of 12
No
Its still a problem.
Regards
Message 8 of 12
imadHabash
HI,
you wrote " NO " this is for a wrong area number exist or the area doesn't appear?
Imad Habash
Message 9 of 12
I did try your measuregeom command but it's not going to work on a curved surface, thanks for your help.
Regards
Message 10 of 12
Kent1Cooper
Is that dish Solid of a known constant thickness?  You can get its volume with:
  (vla-get-volume (vlax-ename>vla-object (car (entsel))))
If you divide that by the thickness [or get a routine to do it], that should give you the surface area.
Kent Cooper, AIA
Message 11 of 12
JDMather
@Anonymous wrote:
Autodesk inventor seems to have the same problem....
Autodesk Inventor does this just fine.
In fact, you marked Inventor as the solution.
http://forums.autodesk.com/t5/inventor-general-discussion/surface-area/m-p/6508172#M609415
Inventor will easily give you the area of an individual face and the total area (iProperties) of the entire part.
Message 12 of 12
carartur16
Hello
After having copied the surface of the solid with the command SOLIEDIT.
You can call the AREA command to know the area of this entity.
