AutoCAD Forum
Subtracting solids
4 REPLIES 4
lee.pellegrin
797 Views, 4 Replies
Subtracting solids
When I use a large solid to subtract multiple parts, once I execute the operation, all of the parts are made as one, How could I do this and still have them as their own entity?
4 REPLIES 4
nwaldridge
in reply to: lee.pellegrin
I usually just copy my cutting object from base point 0,0,0.
Subtract single item, paste cutting object back at 0,0,0, repeat.
AVCPlugins
To do this, you will have to use plugins. for example AVC Drill which has DRI and GAP commands. These commands do each subtraction separately and do not glue the results together. In addition, the commands process the previously selected objects, the subtracted solid is not removed, and you can set up a subtraction with a gap.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
TheCADnoob
If the parts are not physically touching you can use the SOLIDEDIT command to separate them.
Solidedit>Body>separate solids
CADnoob
aucoinleej
in reply to: TheCADnoob
thank you, thank you, thank you
AutoCAD Inside the Factory
