Subtracting solids
lee.pellegrin
Subtracting solids
lee.pellegrin
When I use a large solid to subtract multiple parts, once I execute the operation, all of the parts are made as one, How could I do this and still have them as their own entity?
0 Me gusta
Responder
Soluciones aceptadas (1)
956 Vistas
4 Respuestas
Respuestas (4)
nwaldridge
I usually just copy my cutting object from base point 0,0,0.
Subtract single item, paste cutting object back at 0,0,0, repeat.
0 Me gusta
AVCPlugins
To do this, you will have to use plugins. for example AVC Drill which has DRI and GAP commands. These commands do each subtraction separately and do not glue the results together. In addition, the commands process the previously selected objects, the subtracted solid is not removed, and you can set up a subtraction with a gap.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
TheCADnoob
Solución aceptada
If the parts are not physically touching you can use the SOLIDEDIT command to separate them.
Solidedit>Body>separate solids
CADnoob
0 Me gusta
aucoinleej
thank you, thank you, thank you
0 Me gusta
