- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to cut an object in half. I extruded a line which marks the half way point. My first try, I selected Trim from the surface tab. I selected the white object on the 0 layer as the object to be trimmed and pressed enter. I selected the red plane which is on my CUT layer to mark where I wanted to trim to. It then asked me to select the area to trim. After selecting either half, I get a message stating that the trimming body does not define a trimming area on the picked surface or region.
I then exploded the 0 layer item and repeated the process. Now, it looks as if I have the item separated but both halves are still present. They highlight separately though when I select each. I Simply deleted the half i didnt want now and the elements of the circles that make the hole cutouts that I did not want. The side lines need to be shortened to the midway point now but I'm not sure how to. Also, I need to combine what is left over to make it a new solid. I'm not sure how to do this either.
I am wondering if my thought process for this is correct, of it there's an easier (or better) way to do this. Any help is appreciated.
I've attached the file I originally started working with.
