error with Auto Rebar in AutoCAD 2015
mysteriousmj20
mysteriousmj20
hello. how are you ?? hope you will be good.
issue is defined in this image, you compare the original dimensions with auto rebar(in blue color) dimensions and highlighted Red colored dimension also from autorebar, that also wrong..issue is defined in this image, you compare the original dimensions with auto rebar(in blue color) dimensions and highlighted Red colored dimension also from autorebar, that also wrong..i am using AutoCAD-2015 and  i am facing faulty measurements and calculations issues every time i use auto rebar option feature in autocad for reinforcement of my structural members. error screen shots are attached with this post. must see and provide solution.
john.vellek
Hi @mysteriousmj20,
I am sorry you are seeing this behavior with the Auto Rebar add-in. I suggest you contact the developer directly to see if that can provide any insight on this or if they can point us in the right direction to getting this resolved.
John Vellek
Auto rebar is not reporting the rebar length but the total outside length inches of the beam. You might have something set wrong as to what you want it to report.
I've never used Auto rebar but I hope that you can apply overlap to the rebar length if you are using this for takeoffs.
Thanks.
