AutoCAD Forum
struggling to change text style/size in table to be the same
3 REPLIES 3
s1909128
623 Views, 3 Replies
Hello there,
I am struggling to change the text size on a table to all be the same. Currently I have tried to modify the whole table in 'annotation' and changed all the fonts in the standard table to 'style 4' which I have created. This has not worked to change all the text in the table to be the same style/ size. Could anyone give me any clues on this?
Many thanks in advance!
Lucy
Labels (6)
3 REPLIES 3
pendean
in reply to: s1909128
Select all cells, open PROPERTIES
Change text height
And text STYLE
BUT.. wait you say, these did not change, why?
Because like MTEXT you or someone did a manual edit inside that text editor. A lisp routine floating around the web and in these forums called STRIPMTEXT will remove the manually overrides that you do not want.
HTH
dmfrazier
Try this: Select the entire table, right-click, and use Remove All Property Overrides.
(And if that doesn't work, Undo and wait for better advice.) 😉
DumR0
HI
1)select all cells from table, then properties, find content, find text style... change style , find text height... change ... that's how you can change all at once
2)you have a problem with some cells, that you will need to do this: edit the cell, sellect all content, right click, then remove formatting, remove character formatting. link bellow will help.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Text-i...
AutoCAD Inside the Factory
