I'm a Structural Ironworker in search of "Learning ACAD" & opted to this forum in my pursuit!
..Can I please be guided towards accomplishing this long outstanding bucket list goal?
An Advance Thank You.
@Anonymous, john.vellek has edited your subject line for clarity:Structural Ironworker in search of "Learing ACAD"
Solved by john.vellek. Go to Solution.
This is the forum for Autodesk Structural Bridge Design which is not a CAD program. It is an analysis and design program specifically created for bridge engineers. I suggest you start by visiting the AutoCAD forum at http://forums.autodesk.com/t5/autocad/ct-p/8. Good luck!
What version of AutoCAD do you have?
Hi @Anonymous,
Working in the Autodesk Community Forums, I frequently see requests for learning resources. The Autodesk Community is a great place to get started with Forums, Screencast videos, Ideas, Blogs and Articles to get you started.
Autodesk University is also a great resource to learn how to use your applications.
And of course, AutoCAD also has a great learning channel on YouTube.
One last one you might also check out is Lynda.com.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
Hi @Anonymous,
I am checking back to see if my post helped you with your question. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
