I'm currently using AutoCAD 2015LT.
I'm not sure if I made a mistake when adjusting my Options, but I can no longer grab the grip on items and stretch them in-line with their extension. OSnap is on as well as the extension selection, but I know I used to be able to grab the grip on a polyline and just pull to extend a line. This is proving very annoying since a lot of the things I'm trying to extend to are lines in reference files. Any help is appreciated.
Thanks!
Thanks!
Seems to work OK here in regular AutoCAD.
Have you tried reducing the number of running OSnaps?
Do other tracking modes work?
Can you see the AutoTrack marker (plus sign)?
When you select the grip, do other tracking modes work, ie polar tracking
Do you see the AutoTrack marker (the plus sign)?
AutoSnap tracking turned on? (status bar toggle or F11)
If yes, you should be able to add or remove an AutoTrack marker each time you return to the Object snap point/grip as shown in the animation. Does that work? I don't think Extension will work if the marker isn't present.
Do you have the extention box checked in your snaps under drafting settings?
What is the AUTOSNAP sysvar? (type AUTOSNAP at the command line)
Try with AUTOSNAP = 63 (default)
I feel like I must be on the wrong track troubleshooting, hopefully someone else will chime in. Before I give up though, can you confirm that the AutoTrack marker does appear for other tasks, like tracking from the endpoint of a line.
Doesn't appear to be showing up. I duplicated what you showed in your video using lines and did not see anything. I typically use polylines and tried it with them as well, but did not see any difference. Attached is a screenshot depicting just the grip showing, I don't seem to get the Autotrack marker you mentioned.
Please let me know if you have any ideas, but if not thank you for the effort. I did get to learn some commands I didn't know about before. 🙂
No AutoTrack marker? So you can't use Osnap Tracking at all, as shown in this video? --> http://www.youtube.com/watch?v=GnIww6Ndb2c
Have you used Osnap Tracking previously in AutoCAD LT?
hi, i have found the answer to this, as i used to do this stretching extension lines before in cad2014...
1. Go to Tools > Drafting Settings> Dynamic INput
2. Settings under 'dimension input'
3. Change to only show length change
voila!
apparently by default in cad 2015, you can TAB to change which parameters to change using this dynamic input, just TAB to input the length change...
voila!
