Strange Circles Appearing on Drawing at Intersections
I am creating a drawing of the facade of a building. I have drawn several vertical lines and, in an effort to create a bulbous shape, I knew I had to draw construction lines. I realized that using relative polar coordinates was a good way to go, but before that I looked in Utilities at the Point Style command. I think I inadvertently hit the circle icon, because all of a sudden, little circles began popping up in my drawing! (Will try to attach a screenshot).
Going back into Utilities/Point style, I can't figure out how to eliminate these little circles. Anyone know how to remove these unwanted little buggers? Thank you.
BeKirra
Can you upload the drawing or reproduce the circles on a new drawing then upload it?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
NeilSOC
Those red circles look like the ones that appear when a hatch boundary is invalid. They will normally go when redraw or regen command is run.
imadHabash
By REGEN command line those red circles will gone. it happens when you use HATCH with unclose area.
Imad Habash
This happens quite a bit, seems to be an invalid insertion point.
"RE" regenerate command is a quick fix.
drobertsjr1
Community Visitor
Community Visitor
Gracias.. that was it.
