When I insert block 22225_01 into 22225 Plans (sheet SD-1), the dimensions don't show up. Yes, I've checked layer states. When I open in block editor, there is a ! at all my dimensions. When I insert 22225_01 into my quarter scale template, it appears fine with no !s.
What is going on? I've never had this problem before and I certainly have never seen !s on dimensions.
Thank you
Solved by BillAllenSE. Go to Solution.
I figured it out. I had the dimensions annotative. As soon as I changed that, the dimensions appeared. I guess I need to study annotative dimensioning.
get to know ANNOALLVISIBLE
ANNOALLVISIBLE (System Variable) | AutoCAD 2019 | Autodesk Knowledge Network
