AutoCAD Forum
Storing multiple drawing variations for use in AutoCAD
4 REPLIES 4
469 Views, 4 Replies
I have to make minibuses on a daily bases with different variables like seat placing and such my question is is it possible to make like a modular interface where i can store all the possible seat places and different heights and all my variables to make my life easier.
Thanks in advance.
@Anonymous,
john.vellek has edited your subject line for clarity: Is it posible?
4 REPLIES 4
KimBrunz
You can use one of these programming languages, Autolisp, vlisp, dcl, vba, vb.net, C#.net etc.
Autolisp is the easliest.
Kim
Windows 10 Pro 64 bit
Currently PDS 2018 but testing alternatives
i7 3770k 16 Gb RAM GTX 1070
murray-clack
You may want to look into using Dynamic Blocks with Visibility States for every type of scenario (assuming you have standard measurements that you use over and over again), or, you can look into Dynamic Arrays where you can change the spacing and number of seats dynamically
TheCADnoob
for smaller data sets i would definitely checkout dynaimc blocks as @murray-clack suggests. If the variable change a lot of odependent data i migth go the lisp/scripting route as @KimBrunz suggested.
CADnoob
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
From the description you provide I suspect that dynamic blocks might be the first step to take. You are welcome to attach a drawing or two if you want me to take a look at your exact process.
John Vellek
AutoCAD Inside the Factory
