AutoCAD Forum
how to select one of face on 3D solid object
4 REPLIES 4
toznal
9202 Views, 4 Replies
Hi, there,
I made 3D solid in AutoCAD.
I would like to select face of solid and then add color.
Is it possible to select one of face??
Does anyone know how to do?~
Thank you!
4 REPLIES 4
Alfred.NESWADBA
in reply to: toznal
Use <CTRL> and >click< to select a subobject from your 3D-Solid.
After you have selected it you can use the property window to assign a different color and/or material.
Another option is to start command _SOLIDEDIT ==> Face ==> coLor ... and then select a face on your 3D-Solid.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
toznal
in reply to: Alfred.NESWADBA
Hi! Thank you helping me!!
Its' simply! Thanks!
Can I ask something similar?
Is it possible to paint color to face?
Thank you!
Alfred.NESWADBA
in reply to: toznal
No, it's a CAD-system, not a visualization- or animation software
A workaround could be to create a material with texture map, whereas the texture map is a painted image ... and assign that material to the face.
But that's not very easy to handle.
- alfred -
Alfred NESWADBA
GrantsPirate
in reply to: toznal
Looks like the Hatch command would work for that unless I don't understand what you are after.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
AutoCAD Inside the Factory
