stop changing current layer
Designer_1E
Message 1 of 9
Designer_1E
My current layer is constantly changing without my telling it to.  Usually it changes to the last object I selected or changed.  How do I stop this from happening.  I just want to stay on one layer unless I specifically change it?
Replies (8)
Message 2 of 9
imadHabash
This is a weird behavior that AutoCAD will not do it without an outsource interfere lisps or plugins. SO if you have lately install one then you have to check it out . 😉
Imad Habash
Message 3 of 9
Alfred.NESWADBA
How do you verify that?
My feeling is that you selected an object and then look to the layer-combo or to the property window ... because when an object is selected you will get the object's layer presented.
But when you press <ESC> (at least twice) to make sure no object is selected ... what does the layer-combo or property window show now?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 9
Designer_1E
I'm aware the property box will show what I currently have selected.  I talking about I'll be deleting and move blocks around, and suddenly find the current layer changed to something I touched a dozen commands ago.
For example: I selected the lines on the "stair" layer moved them all to "base_building" then continued working, deleting, moving.  But some how "stair" was made current when it had previously been layer 0.  I need to stay on layer 0 because of the block system we are using.
Message 5 of 9
Alfred.NESWADBA
I can't think about a way to make that happen automatically (as long as their is no 3rd party app installed and working).
To isolate the issue/to find the exact time when that happens you might use SYSVARMONITOR (>>>details<<<) ... add system variable CLAYER to the list of watched variables. This will show you a popup when the current layer was changed to a different one and so give you a feedback when exactly that happens.
- alfred -
Alfred NESWADBA
Message 6 of 9
Designer_1E
Ok, I'll give that a try and see what I come up with.
Thank you!
Message 7 of 9
rkmcswain
CLAYER is the system variable for the Current LAYER. You can use this to monitor it, and to figure out what is changing it.
Message 8 of 9
pendean
Community Legend
Community Legend
I suspect you selected layer STAIR from the pulldown without objects being selected and it because the current layer.
TO confirm: for the next day or two only use PROPERTIES command to change objects' layers, or use LAYMCH to accomplish the tasks.
Message 9 of 9
s.borello
Not typical of AutoCAD.. do you have any add-ins running that may be causing this behavior?
