Can't select objects in tiled viewport with Front View
jona_little
jona_little
When I have tiled viewports I can select objects in all the different ways in Top View. When I switch to the Front view viewport and go to draw a selection window or crossing window instead of getting a selection box I get a dashed line that does nothing. Individual selection does not work either.
In the top view viewport my command line shows and I can select objects :
"Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:"
In the front view viewport my command line shows"
"Command: Specify opposite corner: Specify opposite corner:"
Running Autodesk Fabrication CADmep 2018.0.2
I never had this issue until about a week ago, I've restarted and rebooted with no result and haven't found a reason or solution online.
jona_little
I forgot to mention left and right views in the second viewport work as intended.  As well as front view with a single viewport.
Alfred.NESWADBA
What happens if you change the UCS to VIEW and then try to select objects?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
jona_little
It has no effect on the issue if the USC is in view or World.
Alfred.NESWADBA
Can you then please upload such a dwg-file so we can look into it?
- alfred -
Alfred NESWADBA
jona_little
Figured out the culprit - I was cleaning the drawing up and when I detached the 3 xrefs the various selections started functioning again. Not sure how or why an Xref would affect the front facing tiled viewport.
I reloaded the Xrefs, and object selection is working again, so I guess it was just a gremlin.
Thank you for your time.
