Status bar missing in AutoCAD
Hi, I have had a similar issue on AutoCAD 2019, which also transferred over to AutoCAD 2018. I've tried STATUSBAR followed by <1> and it still doesn't return. Hoping you can help, as I have a lot of work piling up. Thanks
[This post has been split from another thread and updated the subject line for clarity by cheryl.buck: Missing Status bar at bottom of the screen]
injineri
If you "reset settings to defaults" from programs
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Autodesk Community!
If the STATUSBAR variable is set to 1 but it is not visible, it could be a graphics card display issue, that the Status bar was undocked and is off screen, or a damaged user profile.
Try the following:
Please let us know if that helped.
You can use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
pendean
Community Legend
Community Legend
Post a screenshot of your entire AutoCAD program window please, let us see what you see.
Look in REGEDIT (AutoCAD 2019) :
\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R23.0\ACAD-3001\Variables\*STATUSBARSTATE
\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R23.0\ACAD-3001\Variables\STATUSBAR
After changes you have to restart the PC.
Look in AutoCAD, command CUI and check you workspace:
... and give us feedback
