Missing Status Bar at the Bottom of the Screen
mgorecki
Message 1 of 9
mgorecki
One of the designers in my company lost his toolbar that normally appears below the command line.  It normally contains the coordinates, grid info, viewport scale info, snap options, etc...  He doesn't remember doing anything to cause this, but needs to get this back.  If anyone can help me (and him) out with this I'd really appreciate it.  I've already Googled info and have tried the toolbar command (though maybe I didn't look deep enough in the toolbar command.
Thanks in advance,
Mark
[The subject line of this post has been edited for clarity by cheryl.buck from: Missing "Tool Bar" at the Bottom of the Screen]
Replies (8)
Message 2 of 9
cheryl.buck
Autodesk Support
Autodesk Support
Hi Mark (@mgorecki),
I believe you are talking about the Status Bar in the lower Right hand corner of the window. Typing STATUSBAR into the command line and changing the value to 1 should bring it back.
If for some reason this does not work, changing the workspace, then changing it back often works.
All the best.
If my post was helpful, Kudos are always welcome.
And if it answered your question or solved your problem, please select the Accept as Solution button.
[This post has been edited for clarity by cheryl.buck]
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 3 of 9
mgorecki
Hi Cheryl,
Thank you for the information.  I will have to get back to you next year, as the designer is on vacation until then.
Best regards,
Mark
Message 4 of 9
cheryl.buck
Autodesk Support
Autodesk Support
Hi @mgorecki,
Thanks for getting back to me. I will touch base after the new year. Hope you enjoy the holiday if you celebrate.
All the best,
Cheryl Buck
Message 5 of 9
mgorecki
Hi Cheryl,
Thank you, I hope you have a wonderful holiday as well.
Best regards,
Mark
Message 6 of 9
cheryl.buck
Autodesk Support
Autodesk Support
Hi @mgorecki,
Happy New Year!!
I am just checking in to see if your designer has returned and if he had a chance to test my suggestion.
All the best,
Cheryl Buck
Message 7 of 9
mgorecki
Hi Cheryl,
That worked.  Thank you very much.
Best regards,
Mark
Message 8 of 9
cheryl.buck
Autodesk Support
Autodesk Support
Hi @mgorecki,
That's excellent! I appreciate your coming back to let me know, so I've awarded you Kudos 🙂
All the best, and Happy New Year!
Cheryl Buck
Message 9 of 9
asawaya6H4TK
Community Visitor
Community Visitor
Thank you very much
you are a life savior
