Hardware Acceleration
drawingsCHR7R
drawingsCHR7R
Hi Guys,
So something weird is happenning, my hardware acceleration icon is off and when I try to right click on it and go into the graphic performance option it freezes my PC. At this point I have to press escape to bring back functionality.
Does anyone know perhaps as to why this is happening?
jayhar
Hello @drawingsCHR7R
Update your Video Drive and turn off LINESMOOTHING and LINEFADING variables
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Revit Architecture Certified Professional
Thanks You
JAYHAR.M.J
Team Leader
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
vinodkl
I assume the graphic performance window is offscreen and not visible to you.
Try this:
After you right-click on the graphic config(hardware acceleration) and select "graphic performance" from the status bar press alt+spacebr and then type in "M" to move the window then click on the left/right arrow key and move your mouse and now the window will be stuck to the mouse pointer🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
drawingsCHR7R
Oh my goodness! Thank you so much!!
This worked perfectly!! I really appreciate the assistance.
vinodkl
You're Welcome @drawingsCHR7R 🙂
