AutoCAD Forum
Start tab freezing
5 REPLIES 5
patrik
1118 Views, 5 Replies
Start tab freezing
Hi!
I Have problems when I close all tals except start tab, then civil 2018 freeze and I have to wait for at least 30 second before I can Do anything. Does anyone have ideals about this?
5 REPLIES 5
dgladfelter
in reply to: patrik
I had a similar issue some time ago, and the problem ended up being related to my Drawing Template path.
Does the issue persist if you change your Drawing Template path back to the default?
When I encountered this issue, it was due to the Drawing Templates being hosted on a NAS file store (which is not supported by Autodesk).
Donnie Gladfelter
Sr. Manager, Technical Staff Development, Bowman
The CAD Geek Blog
Facebook |Twitter |YouTube |LinkedIn
Cadologist
in reply to: patrik
As a workaround, if your 'NOT' using the Start Tab, you can disable it.
Enter STARTMODE on the command line in AutoCAD and enter 0 (ZERO) to turn off the tab (or 1 to turn it back on).  For more information, refer to the Autodesk Knowledge Network link below......
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
Chad Franklin
Alfred.NESWADBA
in reply to: patrik
NAS drives is a very good hint.
I just want to add ... whenever the Start-tab is activated the list of recent documents is rebuild, so AutoCAD looks to the links for the files and verifies if they exist or not. If that folders that hold these documents are slow (e.g. NAS, or number of files in that folders) then the refresh of this list is slow too. So maybe cleaning the recent file list could help (>>>click<<<).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
patrik
in reply to: dgladfelter
I have changed the path so I test this tomorrow.
patrik
Morning!
I tested and it is the location for "Drawing Template File Location" that matters. I tried to change it to a network path and it didnt work so good.
/P
Technology Administrators
