Want help in converting dwg to dxf format of array polar drawing file
I am not able to convert dxf file of arraypolar command drawing.
I am eagerly waiting for your reply.
Thank you.
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
If I understand correctly, you have a polar array in a drawing file and want to export it to a DXF file format. Can you share this file and tell me the version of AutoCAD you are using and the desired format of the DXF?
Without seeing it, I would make a copy of your file, open it and explode the array and try the dxfout or saveas DXF.
John Vellek
Alfred.NESWADBA
Taking this from the header I would suggest to run command _SAVEAS and select DXF as filetype in the dialog.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I have attached my drawing file here.. I have used 2018 version of autocad.
Thank you
Alfred.NESWADBA
Did my workflow then not work?
Please find the files converted to DXF2010, be carefull, the "Drawing11" has no closed contour as it's intersecting)
- alfred -
Alfred NESWADBA
I am not able to edit that array polar drawing. Is there any way to edit
such drawing?
Alfred.NESWADBA
HI,
>> Is there any way to edit such drawing?
What do you want to edit, the number of array items or the angle/distance? ... then select the array object and look to all the options in the contextual ribbon.
If it's the geometry that was used to built up the ribbon then select the ribbon and find the option "edit source" within the ribbon.
- alfred -
Alfred NESWADBA
