Hi. I am trying to develop a standard office workflow for creating detail sheets (and callouts/references) using the "Place on Sheet" command in Sheet Set Manager. I think I have worked out most of the kinks but have two questions:
I think I have the field set up correctly. Anything else to check?
I skimmed through this tutorial which is really useful and I'm not sure I found the answer to either question to be honest. Can you direct me to a section or page number? Thank you
Here is an example of one that makes no sense. My SheetView / ViewportScale field is set to "Use scale name"
Hello @Crass,
It seems you are trying to create a custom Sheet Set to meet your specific needs.
When creating a Custom Sheet Set you will not use the default template with its default fields. You will what to start by creating a custom template that you link to your new Sheet Set then update or add custom fields.
Take a look at the videos provided, please ignore the version the same rules apply.
Sheet Sets - Title Block Integration - Fields
Custom AutoCAD Sheet Set Template Workflow
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Crass,
Just checking in with you, hope you were able to resolve this.
Natasha
Helpful Links:
