Is it possible to draw a Square to Round lofted sheetmetal part in Autocad 2015? I tried using the loft command but the part doesn't look right. I searched for a "how to" on Youtube but they only have one for Inventer. Any ideas?
Solved by nestly2. Go to Solution.
Solved by JDMather. Go to Solution.
Attach your dwg attempt here.
I didn't Shell it, but see the example here on pg 17
http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%201.pdf
This is what I'm trying to draw using AutoCAD 2015, size is not important at this point, I just want to know if it's possible, and if so, how?
Add fillets in the corners and nodes to attach your Guide curves.
Of course Inventor does it for you - simply click the circle and rectangle.
Most likely guides are going to give the best results for that shape, but there's also a lot you can do with loft settings either during, or after the loft is created.
