I have recently had a problem that spell check was not working in my drawings in AutoCAD 2015. It has definitely worked in the most recent past.
I thought if it is not working maybe it was time to update to AutoCAD 2018.
My install went quite easy but still when I tried to do a spell check, I get nothing. I even typed over existing words and make them extremely wrong within the text on the current drawings and title-blocks but nothing is picked up to be spelt wrong.
Another weird thing is when I add new text to the current drawings that is obviously misspelled, spell check catches that word only?!?!?!
Solved by pendean. Go to Solution.
Hope this helps.
@DalyceTwrote:
I have tried this from a few difference peoples files and still spell check does not correct spelling mistakes still.
If I understand correctly, it works but it doesn't check the spelling correctly.
Please then double-check the dictionary you use in "Options". The process is descripted in the link which both Dean & I attached.
Select the correct dictionary:
HTH
Did you try to Repair your AutoCAD installation? If you log on to your workstation as a different user does it work? If so then perhaps your user profile is corrupt?
Before removing your personal settings, can you attach a sample dwg file with the problem here ( I am using v2016)? I suspect there is a drawing file issue.
Or can you confirm that this problem can be found in every drawing file?
