AutoCAD Forum
Something change with Blocks?
3 REPLIES 3
BillAllenSE
339 Views, 3 Replies
BillAllenSE
I'm running ACAD LT2021.
Has something changed with Blocks?
Before, after I create a block and then select one element to move the whole block, that would work.
Now, after I create a block and then select one element to move the whole block, only the element I selected moves. It's like the block wasn't even created, except it shows up when I list blocks and when I try to create the block again, I get a message saying I've already created a block with the same name.
What am I doing wrong or what has changed?
Thank you
Thank you
3 REPLIES 3
BillAllenSE
in reply to: BillAllenSE
BillAllenSE
I didn't mean blocks. I meant groups.
Kent1Cooper
Kent1Cooper
Read about the PICKSTYLE System Variable.
Kent Cooper, AIA
Kent Cooper, AIA
BillAllenSE
in reply to: Kent1Cooper
BillAllenSE
Thank you!
Thank you!
AutoCAD Inside the Factory
