I'm running ACAD LT2021.
Has something changed with Blocks?
Before, after I create a block and then select one element to move the whole block, that would work.
Now, after I create a block and then select one element to move the whole block, only the element I selected moves. It's like the block wasn't even created, except it shows up when I list blocks and when I try to create the block again, I get a message saying I've already created a block with the same name.
What am I doing wrong or what has changed?
Thank you
Solved by Kent1Cooper. Go to Solution.
