AutoCAD Forum
Some tabs on ribbon section are missing
4 REPLIES 4
499 Views, 4 Replies
As I said in the title, some tabs on ribbon section are missing and i can't bring them back. I searched the forums and i tried almost every method suggested and nothing happened. What should I do to fix the problem?
4 REPLIES 4
pendean
Looks like you (or someone else) tried to recreate a custom AutoCAD Classic workspace, with lots of duplicates, and which has no extra Ribbon attached to it on purpose. You got what you set the program to show.
Why don't you just change your workspace from "CLASSIC" to another one to get the Ribbon back.
Then you can turn on and float or dock all of those extra unnecessary toolbars if you still really need them
in reply to: pendean
Thanks for tips. But there are no options except "Calssic" and "3D Modeling" under the workspace settings. I don't know if it's the way it should be or if there's something missing.  I tried to switch from classic to 3D but it didn't help either. I tried customize the setting of the current workspace and I couldn't find anything that changes this under options. I can't figure out where or what is the problem.
carlos.ramallho
Olá, seja bem vindo a comunidade. (Welcome to Community)
  • Tente alterar essa opções do WSCURRENT.  (Try to change the option on WSCURRENT)
  • Tente também o comando RIBBON (Also try RIBBON command)
  • Ou tente adicionar -TOOLBAR>>ALL . (Or try to add -TOOLBAR>>ALL)
  • Se não der certo tente: (If it not works try this on video)
Se a resposta te ajudou a solucionar o seu problema clique em "ACEITAR SOLUÇÃO", isso ajuda os outros usuários a encontrar rapidamente uma resposta, se gostou clique em "CURTIR".
pendean
You are a repair/reinstall or removal/reinstall in your future then: ask the person that setup your AutoCAD for help and guidance to put back any customizations you will lose first.
Forma Design Contest
AutoCAD Beta
