AutoCAD Forum
((SOLVED)) Occurred problem in text tool
6 REPLIES 6
UGS_240067_eccat
635 Views, 6 Replies
When I type a number or a symbol in the text tool, it shows me it but inversed like when I type 1000, it present it like 0001.
6 REPLIES 6
CGBenner
in reply to: UGS_240067_eccat
@UGS_240067_eccat Welcome to the forum.
Is this the correct screen shot?  I'm not seeing the inverted text that you mention.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
@UGS_240067_eccat ,
Are you using AutoCAD Electrical for labeling or a third party software?  [AutoCAD Electrical Forum]
Try an Audit and Regen - or Post the drawing.
Also, check the text Properties is not Backward or Upside down:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
UGS_240067_eccat
in reply to: CGBenner
The numbers and Fμ should be μF and else.
Thanks, but It's already off.
apjones
Check your current text style....
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Thank you all for your help, but the problem is solved when I changed language for non-unicode program from Arabic to English (US) in administrative language settings.
AutoCAD Inside the Factory
