MULTI LINE TEXT ATTRIBUTE
trumankiko
Message 1 of 10
trumankiko
i have a multi leader style with block in it and this block has 2 attributes. one with a single line text and one with a multi - line text. i have no problem editing the single line attribute. but when i try to edit the 2nd attribute, my screen zooms out and when i exit the editing tab for attributes, my model space is also zoomed out that i have to find my drawings again. can pls somebody help me??? :<<<<<<
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Wondering if you just need to turn off UCSFOLLOW command (usage is explained in HELP).
Message 3 of 10
imadHabash
Would you attache here a CAD drawing sample please, we need just the second attribute for testing?
Imad Habash
Message 4 of 10
trumankiko
hi, while checking my dwg on another pc, i got another problem. after i pointed my mleader, the attribute editor does not show. can u pls help mee
Message 5 of 10
awysockiP3MJC
I have that same problem but i have not found a solution. This is only happening in a certain dwg and no other dwgs has this problem.
Message 6 of 10
awysockiP3MJC
I have found the solution on my end so maybe this may help anyone else. So my block had a the same block within a block that had an insertion point miles away. that being said all i had to do is explode the block and that fixed this issue for me.
Message 7 of 10
pendean
Community Legend
Community Legend
Can you explain more please, perhaps add screenshots too?
Message 8 of 10
awysockiP3MJC
Can you attach the block to this post?
Message 9 of 10
pendean
Community Legend
Community Legend
See message #4 above your post.
Message 10 of 10
awysockiP3MJC
not an image but the actual CAD block
