Solid subtract not working?
Message 1 of 11
Am using Autocad 2016.
A book I am reading says to use Solid subtract to delete blocks from the walls at the door locations.
I tried this but nothing gets deleted.  Why is this?
Thank you for your help.
Replies (10)
Message 2 of 11
Patchy
Subtract a BOX it can do; but a BLOCK, no it can't.
Message 3 of 11
Sorry, I meant to say Box, not Block.
Message 4 of 11
Patchy
Attach your drawing so someone can test it.
Message 5 of 11
It it attached.
Message 6 of 11
Hi @Anonymous,
You are using surfaces instead of soild walls, so you must subtract box/block from both sides of wall or create your 3D walls use Polysolid command in the solid tab of ribbon.
Message 7 of 11
Where is the Polysolid command?
Message 8 of 11
You still beginner @Anonymous I advice you to learn some courses in 3D.
This is the Polysolid
Message 9 of 11
Ah!  It is not on the Solid Editing panel.
Message 10 of 11
I succesfully drew Polysolids.
But when I delete the boxes, no holes remain.  It just disappears.
Message 11 of 11
JDMather
Attach file here that exhibits this behavior.
