Solid(continuos) lines appearing as dashed lines in the layout
I am using autocad 2019; After my drawings and i wanted to plot it, then as i clicked on the layout in order to start plotting, all the lines appeared as dashed lines. even as i continued in order to see what will be the final outcome, after plotting it, all the lines remained as dashed lines.  pls help me, what
do I do
imadHabash
would you please attache here a few lines from your dwg for testing ?
Imad Habash
Attached is the sample of the lines appearing as dash lines during plotting
Alfred.NESWADBA
Sorry, nothing attached.
For attachments please do not reply via your mail system. Instead use your Internet browser to reply, there you have the possibility to attach a file.
Another idea: if you use a plot style (CTB or STB) then please try plotting without plot styles.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
