Object Snap Settings Issue
Message 1 of 9
I've been using my AutoCAD for a few days in a row now, and today when I opened my program and I started drawing, my shift+right click wasn't showing the Object References as it usually did, and now I need to draw some tangents and I can't find the way to do it without the shift+right click.
I've tried Settings on Options and User Preference but hasn't been working.
Help please, I'm dying here!!
Replies (8)
Message 2 of 9
Alfred.NESWADBA
not sure to understand ... are you missing the context menu (as you wrote "shift+right click wasn't showing the Object References") or the object snap?
First could need to turn on PICKFIRST
For the second one ... does <CTRL><RightClick> work?
If you have not done customizations and you are missing the context menu you might reset the AutoCAD profile to default (>>>click<<<).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
I'm sorry yes, I meant the Object References in the context menu, I'm missing the context menu when I'm running a command and I press ****+right click it used to show me the Object References, and now it doesn't.
I had PICKFIRST turned on already.
And CTRL+Right Click is not working either.
I actually have done customizations so It'll be kind of sad to set it to default... is there something else I can do?
Message 4 of 9
Alfred.NESWADBA
Am I correct that you mean you are missing this context-menu:
If I'm correct then please try:
  • start command _LINE so AutoCAD asks you for the first point
  • now, make sure the mouse is in the middle of the graphic part of AutoCAD
  • now press <SHIFT><RightClick>
...what do you get?
- alfred -
Alfred NESWADBA
Message 5 of 9
That's the Menu I'm missing, so I do shift+right click and nothing happens, as if I hadn't pressed any button.
Message 6 of 9
Alfred.NESWADBA
Have you started command _LINE and are you asked for a point when you press <SHIFT><RightClick>?
- alfred -
Alfred NESWADBA
Message 7 of 9
Yes, I press shift+right click while running the command LINE.
Message 8 of 9
Alfred.NESWADBA
then please follow the reset settings suggestion (>>>details<<<), it's faster than searching now for the source of the issue. And as you are new to AutoCAD I guess you have not done customization's yet.
- alfred -
Alfred NESWADBA
Message 9 of 9
Thank you so much for your help! I did it and it worked! Hope you have a great day!
