Modeling a terrain (solid, not a mesh) with a soft surface
teocruz105
Message 1 of 13
teocruz105
I need to model a solid terrain in autocad. I created the level curve in AutoCad 2020. Then, I imported the file to Autocad Architecture and create a mesh, with a very good looking surface. Since I need the terrain as a solid, I converted the mesh into a solid and imported it back to AutoCad 2020.  The issue is that the solid had a very bad surface when I imported it and delete the polylines. And it looks veven worse when I convert the file to an STL. How can I create a terrain in AutoCad with a very nice furface, but still a solid?
Replies (12)
Message 2 of 13
j.palmeL29YX
Can you post the files (the mesh, the solid) here?
And maybe two images (poor quality, good quality).
Jürgen Palme
Message 3 of 13
Alfred.NESWADBA
Try to set FACETRES to 10 (default value is 0.5), then run command _REGEN ... better? (also the export to STL is more fine).
I would use Autodesk Civil 3D, depends on if you have access to it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 13
teocruz105
Here you have the file as a mass, I convert it to a solid and the surface does not look good. If I use the command Smooth, it will become a mesh...but I need it as a solid and looking well. I have attached a stl file as well.
Message 5 of 13
Alfred.NESWADBA
[EDIT]deleted[/EDIT]
- alfred -
Alfred NESWADBA
Message 6 of 13
teocruz105
Yes, I did. I set it to 10 and then I did a regen, but it remain more or less the same.
Message 7 of 13
j.palmeL29YX
@teocruz105 wrote:
Here you have the file ...
No attachments here 😕
Jürgen Palme
Message 8 of 13
teocruz105
Sorry, here are the attachment. As I said before, I need to have this terrain as a solid, with a smooth surface. When I converted to a solid, and erase the original mesh, aspect of the surface changes. And that aspect is the one I will see as a stl file, too. If I select "No" to erase the original mesh when converting it to a solid, it will look fine, but that is only because the mesh is still covering the solid. But when I export it to stl, only the solid will be converted, so the aspect will look bad. I have attached a stl, too.
Message 9 of 13
j.palmeL29YX
@teocruz105 wrote:
...  and erase the original mesh,
Can you upload the "original mesh" too?
Jürgen Palme
Message 10 of 13
teocruz105
Here it is...the file with the original Mesh
Message 11 of 13
j.palmeL29YX
Aha. Your "Mesh" is an AEC_Mass_Element. That's a completely other world.
I'm not familiar with those products, but I guess, this Surface only LOOKS good, the VISUALISATION is smoothed, but intern it is modeled always as a lot of small triangles. (maybe someone will correct me).
To get a smooth AutoCAD-3DSolid, you must create a smooth modeled element.
In the attached dwg (coming soon, 100+ MB) I did this:
- Explode the AEC-object to get a 3D-Solid
- Slice the 3D-Solid into small disks
- Extrakt the upper conture of this disks as Splines
* Xedges command
* Delete all not needed lines
* join the lines of the upper contoure to a polyline
* Smooth the polyline (pedit -> spline)
=> result a bunch of Splines (green)
- create a lofted surface using this splines.
- create a box and slice the upper part of the box using the lofted surface
=> the yellow 3DSolid.
To improve the quality of the Loft may add some splines to use as Guides (here 3 blue splines).
=> the red 3DSolid.
I know this involves some effort, but perhaps it will help to achieve the desired goal.
If my reply solves your problem, click the "accept as solution" button. This can help others find solutions faster.
Jürgen Palme
Message 12 of 13
j.palmeL29YX
... and >>here<< the missing file.
Jürgen Palme
Message 13 of 13
teocruz105
Thanks for the suggestions. I seems autocad does not have an easy way to do this. I'll keep trying this steps. If I solve it this way, I'll post it here.
