Hi All,
Will Autocad 2024 and Auto tracker run on the new Snapdragon X Elite on Surface pro 11
Nope
From system requirements: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
ARM Processors are not supported.
DarrenP
Dose this mean even with emulation it wont work. I know Auto desk official stance is that it wont work on ARM processors but i have seen some comments on line that it will
@ku69454 wrote:..but i have seen some comments on line that it will
Where please? I suspect you're just a year or five too early for AutoCAD to go there, best i can find is
@ku69454 wrote:Dose this mean even with emulation it wont work....
Why not test it and find out
Is your intent to only use AutoCAD casually or occasionally? Then this is likely your better option
https://www.autodesk.com/products/autocad-web/overview?term=1-YEAR&tab=subscription
@pendean Thank you so much for your response.Really appreciate it.
Honestly i cant remember where i found the statement. I am looking to purchase the new surface pro 11 that has the Snapdragon X Elite so i cant really buy it and insatll CAD and test it. Unless Microsoft have a good return policy 🙂
AS for the use i would like to actually do some 2D drawings on CAD so was hoping to use the main version of CAD
@ku69454 wrote:
....AS for the use i would like to actually do some 2D drawings on CAD so was hoping to use the main version of CAD
Judging solely by what little I have found, including that DWGTRUEVIEW review, I recommend you either go with AutoCAD for MAC to enjoy a robust ARM platform, or purchase a more traditional laptop solution (even from Microsoft if you like fan-free super-light devices that throttle back hard on performance when it is not plugged into a power source).
Best wishes.
Dear All,
Hope you are doing well. I actually manage to run revit and autocad on surface pro copilot / snapdragon plus processor and it is perfectly fine. I had not tested it for large files yet.
hey mate, if you can show perhaps a youtube video of revit on snapdragon that would be ace!
I doubt Autodesk will churn out versions of their most popular titles for processors that aren't main-stream. Let alone all of them. Like Mac-users are begging for a Mac version of Revit for years now and it won't happen.
So keep in mind what software you want to use if you're shopping for a new computer.
