Autocad TRIM and Extend Command
Code_x
Code_x
Hello, I'm experiencing some issues with AutoCAD 2024. The trim and extend functions don’t work like they used to, which is slowing me down significantly. Could anyone guide me on how to revert these commands to behave as they did in AutoCAD 2020? Thanks!
cadffm
Read the help[F1] about both commands,
and the 2021 whats new topic
https://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-A343CF22-706E-4F58-9CE4-B48CBCA3589B
You will learn about the new default  'quick mode'
and how you can change it to the standard mode (this is how you know it from previous version).
HTH
Sebastian
esd1953
I AM USING THE "OLD" standard mode and it is still not working right. If i change projmode to 0, 1 or 2 it doesan't make any difference it will still not see a line to extend to unless it is crossing. what other setting is there that i am missing?
pendean
Community Legend
Community Legend
@esd1953 wrote:
...If i change projmode to 0, 1 or 2 it doesan't make any difference...
FaracheI
Observer
Observer
Using the command 'setvar edgemode 1' worked for me to solve this problem.
https://forums.autodesk.com/t5/autocad-land-desktop-read-only/extend-to-apparent-intersection/m-p/16...
